Dear community,
The following problem occurs alot for me. In my use of Revit I like to create alot of Revit families. This avarages out to almost 2 or 3 families per day.
My following problem is that I have a family template for windows for example and I make loads of window families from it. This template has way more parameters than I usually need, so that I just have to remove the parameters to create a new window family. The problem is that deleting is those parameters is alot of work. It would save alot of time to just be able to use the "windows delete" button to do this and give it a enter to finish.
I know that it is a very small issue, however because I believe it to to be as easily solved I thought I post it to the forum.
Kind regards,
Sefanja
PS: Here is an example, everything inside the red boxes needs to be deleted.
