Style and Display panel not under the Manage Tab
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
2082 Aufrufe, 6 Antworten
I was working on a project and need to change the cut plane for a certain style of wall, only to discover that style manager was missing. In fact the entire Style and Display panel was missing! (screenshot attached below). Any solutions?
Thank you in advance,
Beschriftungen (1)
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
There is no "Style and Display" Panel. Also the "Cut Plane" is set in the View Range.  Can you elaborate on what you are trying to do?  What do you mean by "change the cut plane for a certain style of wall"?
...are you wanting to place a Plan Region in the View?
Nachricht 3 von 7
als Antwort auf: barthbradley
I know it is possible to only change a selected wall or wall style's cut plane height while leaving the rest the same. However I do not know how to access the style manager.
Nachricht 4 von 7
I don't know what you are talking about.  Can you be a little more descriptive?  What do you want to do exactly?
Nachricht 5 von 7
I want to select a wall, and change the cut plane's height for that wall. While leaving cut plane's height the same for everything else.
Nachricht 6 von 7
Like I said above, it sounds like you want to place a Plan Region (View Tab=>Plan Views).
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
Nachricht 7 von 7
I must be scatterbrained today, thank you for your patience.
