Student Version not getting activated
8 ANTWORTEN 8
Nachricht 1 von 9
515 Aufrufe, 8 Antworten
Yesterday I downloaded Revit 2019 Student version and Autodesk gave me SERIAL NUMBER and PRODUCT KE. After complete installation etc, when I opened REVIT 2019, it asked me to Activate without giving me option to run(you can see it in Screenshot attached). There was NO 30 days free trial to RUN because that's where I registered my autocad by running it and going to licence option and entering serial number and product key simply. Now When I try to activate, it shows error(screenshot attached). What can I do to enter serial number and product key and get registered for 3 years?
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
8 ANTWORTEN 8
Nachricht 2 von 9
ennujozlagam
als Antwort auf: Anonymous
you can contact Autodesk Technical Support and let them know your issues. thanks
Nachricht 3 von 9
Lakshman01
Hi @Anonymous  Make sure your Internet connection is enabled and try once, if its not possible means, Go ahead with another option -->I have an activation Code & Registering with Autodesk. (Before you copy the Request code).
Regards
Lakshman
Nachricht 4 von 9
als Antwort auf: Lakshman01
Lakshman brother I tried it with internet connection + I have tried the other option as well but didn't work either. Also I tried to request activation code from https://register.autodesk.com but didn't work
Nachricht 5 von 9
ennujozlagam
try to do a clean uninstall and reinstall again your program and see if helps. thanks
Nachricht 6 von 9
RDAOU
@Anonymous
You could just try to repair installation first AND also try to reboot windows after installation? It could be that simple
Nachricht 7 von 9
als Antwort auf: ennujozlagam
how much more clean install can there be when I did a new window last night and the first software I downloaded and installed was revit
Nachricht 8 von 9
als Antwort auf: RDAOU
yes I did
Nachricht 9 von 9
RDAOU
@Anonymous
Try the following same order and see if it works
  1. Reboot the computer & QUIT any background applications from  CTRL + ALT + DEL >> Task Manager
  2. Insure you are connected to the internet
  3.  Disable Anti Virus and Fire wall and  ADJUST/CHECK PROXY SETTINGS to ensure an uninterrupted connection
  4. Run a Repair Installation
  5. Reboot
  6. Run Revit as Administrator
If the above does not resolve it then try to Reset the Licensing (2017 - 2022 products)
