Stuck Between installed and unistalled revit
kaitlyn.kane
kaitlyn.kane
Community Visitor
Community Visitor
I had Revit 2023 downloaded but it would only run in viewer mode. I tried to uninstall it and reinstall it to see if that would resolve the viewer mode issue but when I went to reinstall Revit 2023 it told me that Revit 2023 was already installed. So now I can't even access Revit on my computer. I have included a picture that shows that there is only one file in my Revit 2023 file.
DarrenP
try using this method for a clean uninstall: http://knowledge.autodesk.com/customer-service/installation-activation-licensing/get-ready/remove-pr...
DarrenP
Lachlan-JWP
Use the Autodesk Uninstall Tool which should have been installed on your computer when you installed Revit. It can be found in the Autodesk folder in the Start Menu.
