Stuck at item # 10 revit 2018
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
478 Aufrufe, 9 Antworten
OS win 10... Exercise 8-3 creating a section view... well here I am at item # 10 pg 8-9, can't move forward.  'seems that the book doesn' t match the drawing... hey all my drawing shows is the rectangle with datums showing and this is from THE exercise files, not mine &.... where is my previous post.. also can't find my profile.. can't find the drop down.  oh couldn't find the problem on my drawing either...that's why I went to the exercise files.  how I tag?
signed
computer literate
novice?  no
9 ANTWORTEN 9
Nachricht 2 von 10
leowarren34
als Antwort auf: Anonymous
@Anonymous  This the community feedback forum, I'll ask the admin to move this to the revit forums.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Nachricht 3 von 10
als Antwort auf: leowarren34
ok
Nachricht 4 von 10
RDAOU
@Anonymous
Which book, what exercise...Read your question several times but I couldn't get one single clue on what you are trying to do and what is not working out as per the book
Nachricht 5 von 10
MostafaElashmawy
Better to share what exercise or tutorial do you mean?
Mostafa Elashmawy
Nachricht 6 von 10
als Antwort auf: RDAOU
book: revit from the ground up 2018.. already told you the exercise
Nachricht 7 von 10
als Antwort auf: MostafaElashmawy
book: revit from the ground up 2018... told you the exercise.
Nachricht 8 von 10
leowarren34
@Anonymous You'd get more help if you posted the exercise itself, therefore those that don't have the book can pitch in.
Leo Warren
Nachricht 9 von 10
MostafaElashmawy
We don't have access to that book. Share a screen shot of the exercise.
Mostafa Elashmawy
Nachricht 10 von 10
martijn_pater
@Anonymous Your frustration is understandable, but you should really re-read your own question as someone else would who wants to help you. Please just write out full sentences and specifics, and then you will get all the help here you'll need for any Revit issue you are having... :leicht_lächelndes_Gesicht:
