Anyone please tell me where I can find structural plan view in revit lt 2019?
In full version, it's in view --> plan views. Now, it seems to be missing from that menu.
Thanks!
Do you mean it doesn't have structural plan view or doesn't have whole structural system? It has menu structural walls, floor slab, columns, beam, etc. though.
Hi - Yued Yuthdanai S. ![]()
Nowadays, Can you do it?.....I don't understand too.
If it hasn't structural plan view....Will we can draw or present a work perfectly?
Or you have other methods?......Please share me ![]()
--tao-trairat.....your friend--
I realize that this question is for Revit LT 2019, so it is a few years old. But I am using Revit LT 2023 and Can't seem to get a Structural Floor plan. Even when Using my Template which was created in Standard Revit, and shows levels 1 and 2 to be a Structural Plan - Modeling View in the Properties. When I go to edit type it says it is in the Structural Plans: System Families category. If that is the case, one would think that is is somewhere within the models available families, however when I go to add a level it does not provide the option. so basically I am stuct with 2 level floor plans that are structural plans and all others are just floor plans. Kind of stinks in my Browser Tree
were you able to do a structural framing plan? I want to create simple foundation and framing plans. Is there a work around where you just do it in linework?
no, unfortunately, I have found no fix for this as of yet. Everything I have found seems to indicate that I can only create multiple structural levels in the full revit version; LT does not have the option. It does apparently have the option to use a structural plan view if it was created in the full version though.
