structural model: Test if wall is connected to an element underneath
3 ANTWORTEN 3
Nachricht 1 von 4
pipapongo0909
450 Aufrufe, 3 Antworten
Hi forum,
I am looking for a (semi) automated way to validate our model. I would like to check if every structural element is "connected" ( just that they share a common surface) to at least one element underneath. If this would not be the case, it would mean this element would be flying around which obviously represents a mistake in the structural model.
As far ass i know this is not possible with Navisworks so it might be possible to built a workflow with dynamo...
Does anybody would have an idea?
thanks in advance
pipapapongo
Jeff Wurth
BIM Manager | Dipl Ing. Bauingenieur
LinkedIn
3 ANTWORTEN 3
Nachricht 2 von 4
Karol_Piroska
als Antwort auf: pipapongo0909
go to structural settings, analytical model tab and mark all checks you require. If something is not connected as it is supposed to be you'll get a warning message (manage tab, warnings).
Nachricht 3 von 4
pipapongo0909
als Antwort auf: Karol_Piroska
Hi @Karol_Piroska,
Well thanks i did not know this feature yet. I played around a little an found already several errors.
thanks a lot.
Do you happen to know the Revit Modelchecker by Biminteropabilitytools?
judging by the videos it is more adaptible but i havn't tried it yet.
Have a nice day
Jeff Wurth
LinkedIn
Nachricht 4 von 4
Karol_Piroska
nope, haven't used it. This built-in one does the job so it is enough for me ..
