Structural Model not showing up
6 ANTWORTEN 6
Nachricht 1 von 7
2277 Aufrufe, 6 Antworten
Can someone tell me why the structural model does not show up in the architectural model? We have tried everything we've looked at work sets we looked at visibility graphics we reloaded it created a new central file for the original model and checked rabbit links to make sure everything is set properly. Still not showing up. Has anyone had to copy the contents of a structural model and insert it into a blank file for this to work? I'm at my wits end and facing a deadline ....
6 ANTWORTEN 6
Nachricht 2 von 7
Alfredo_Medina
als Antwort auf: Anonymous
Welcome to the forum.
Some things that I can think of:
1) The structural model link is there, but the file is empty.
2) The view(s) in which you are trying to see the structural model is (are) set up to show a different phase.
3) The structural model link is off in the view.
4) The structural model link is hidden in the view.
5) The structural categories are off in the view.
Nachricht 3 von 7
als Antwort auf: Alfredo_Medina
Could you possibly explain each of those? I did just get a message when i relinked the structural model about not seeing the model b/c its out of range or something ....
thanks so much!!!
Trista
Nachricht 4 von 7
renanrr3
Can you post the message you got here?
Since you mentioned it says something is out of range, is it possible that the linked model is positioned differently from your architectural model?
Nachricht 5 von 7
Pshupe
First thing I would check is the discipline in the view.  Make sure it is set to coordination.  Have you looked in the 3d view?  Normally that view is set to coordination by default.  Turn off the crop region in the view and zoom to fit.  Check the project base point in the structural model and link origin to origin.  If that doesn't work try center to center.  Check the structural model to see if they are using shared coordinates.  Check the manage link tab to make sure it shows up there and is loaded. Check the VG of the view to make sure it shows up under links and is checked under visibility.
There is no reason to copy model objects and place in a new project.  Can you ask the structural consultant what's up with their model?
Cheers Peter.
Nachricht 6 von 7
als Antwort auf: Pshupe
Thank you. I will try these suggestions soon. For now, I decided to go back to my v2015 because I just couldn't make it work.
But I will need to know for next time ...
Thanks again!
Trista
Nachricht 7 von 7
set the detail level to fine
