structural framing workplane
6 ANTWORTEN 6
Nachricht 1 von 7
ar00302
432 Aufrufe, 6 Antworten
I have placed two structural concrete beams on two different levels.
The first beam has a reference level
 The second has also a workplane and an orientation parameter.
How I have done that?
Thank you.
6 ANTWORTEN 6
Nachricht 2 von 7
ralphdenhaan
als Antwort auf: ar00302
Did you use a sloped plane as work plane??
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Nachricht 3 von 7
ar00302
als Antwort auf: ralphdenhaan
No i have place on a level
Nachricht 4 von 7
ralphdenhaan
The Orientation only appears when your Structural Framing is on a Work Plane. So the first one of your print screen is not on Plane anymore.
Nachricht 5 von 7
ar00302
Nachricht 6 von 7
RPTHOMAS108
Likely one was placed in the plan view associated with the level and the other wasn't. Same plan view used with both levels one level associated with the view the other not.
Structural framing becomes detached from reference level occasionally also due to large offsets away from refence level etc.
Nachricht 7 von 7
GaryOrrMBI
In addition to the other comments, If you change either the Start Level Offset or the End Level Offset it will cause a dissociation with the plane...
You can always reset those values to 0" and use the Modify -> Edit Work Plane tool to reset it to the desired plane.
-G
Gary J. Orr
GaryOrrMBI (MBI Companies 2014-Current)
aka (past user names):
Gary_J_Orr (GOMO Stuff 2008-2014);
OrrG (Forum Studio 2005-2008);
Gary J. Orr (LHB Inc 2002-2005);
Orr, Gary J. (Gossen Livingston 1997-2002)
