Hello to everyone
Someone knows if there is any chance to export metal estructural framing from Revit to Navisworks?
I'm using version 2020, and already have the updates
I also note, that the structural framing not compatible with navisworks is the one which use sub-connections.
I already search the forums and apply the suggested solutions. (Put structural elements in "fine", in the export options use "entire project", etc.) but nothing works.
If this elements (metal structural elements with sub connections) are not compatible with Navisworks, which elements should i use?
Thanks for your support
