Hello
I am trying to use a Structural Framing system which I host on wall or roof planes and then use some custom profiles for the framing.
The problem is that when I change the boundary of the framing system, the Z justification of structural framing profile are always resetting to Top. Even after I select all profiles and change the Z justification, they will always reset to Top so in my ase they will collide with the wall/roof surface.
See an example usage bellow
So I have two questions.
First, is why is this happening and if there is a way to always override to Bottom justification
Second question is why there is no way to at least change the justification globally, without always having to select the profile elements in the view.
