Structural Foundation Not Displaying Dashed on 1 Side.
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
BigPicture045
526 Aufrufe, 9 Antworten
I can't, for the love of drafting, figure out why this Slab Foundation is not displaying dashed on both sides. It's displaying as solid lines in printed plans. When zooming in/out, the line changes visibility between dashed/solid.
Why is the scale having an effect on this?
scale 3/32"
But If I change the scale to 1/4", it displays correctly:
Close up view:
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: BigPicture045
Betcha the line is coming from an annotation (maybe Section Marker) that has its "Hide at Scales Coarser Than" set to 1/4" scale.
...reverse of this:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Section-markers-do....
Nachricht 3 von 10
jay_colcombe
Agree with @barthbradley that something else is influencing this!
At the 3/32" scale use Tab key through the View/Viewport to cycle select the other element which is in view to identify what it is.
Jay Colcombe
Autodesk Certified Instructor
Nachricht 4 von 10
BigPicture045
There are no other elements that this line could be coming from. It is coming from the element to my knowledge. It seems to be location based. The one in the middle is the original, but if I copy over to the left, it displays correct, but if I copy to the right, is displays incorrectly:
Why would the scale be affecting half the lines on the element, on this portion of the view?
Nachricht 5 von 10
BigPicture045
als Antwort auf: barthbradley
Nope. No section markers there.
Nachricht 6 von 10
SteveKStafford
What are the View Range, underlay and discipline settings for the view?
Steve Stafford
Nachricht 7 von 10
Cut a section across the foundation and share it here.
Nachricht 8 von 10
BigPicture045
Fortunately, I was able to solve this by using the linework tool. However, I was unable to figure out what was causing this.
Nachricht 9 von 10
jay_colcombe
What ever works to get a solution!
just a caveat, if you look at the horizontal lines between the pad bases these appear to be linked so is this an Underlay or linked file or the outline of a floor boundary?
Jay Colcombe
Nachricht 10 von 10
BigPicture045
als Antwort auf: jay_colcombe
These are the outlines of structural slabs.
