Structural elements from IFC not showing
1 ANTWORT 1
Nachricht 1 von 2
Xapod
667 Aufrufe, 1 Antwort
Hello
I am trying to Link an IFC file in Revit 2018. It seems that the IFC file is linked, however i can only see a part of the structure.
Most of the beams are shown (not all) and none off the columns.
I checked the V/G and column and turned everything on without result.
I Setup the the views to show the linked files (see attachement).
To make sure there wasn't a problem with the IFC i opened it in a model checking software and there you could see the entire structure.
Does anyone have an idea how to solve this?
Kind regards,
1 ANTWORT 1
Nachricht 2 von 2
Xapod
als Antwort auf: Xapod
Fixed the problem by opening the ifc as a revit file and then linking the rvt file into my project.
