Structural Columns visible on all Levels
Kev_D
Kev_D
Hi all
For some reason all our Structural columns on the parking levels are visible on all above levels. The view range is set to each level properly. No underlay set. No plan region. No filters. Nothing else I can see. We first noticed it in the Arch model with the Str model linked in so we thought it was a position issue, but when I opened the Str model you can see the underground columns on level 24 for example (but the same applies to all levels).
Columns at P1 Level, but visible at Level 24
View Range for Level 24
I am wondering is there something within a Structural Column family that shows some representation way above the level it is placed on?
Could be a few explanations for this behavior. Post the File here and we'll find the explanation quicker than guessing.
Kev_D
@barthbradley I was stripping down the model to only show the levels and the columns and I discovered an element in the family that was not locked to a reference plane properly so that was extending multiple levels above therefore cutting through the cut plane of each level which ended up showing the columns. Considering you requested the model which forced me to clean/strip it down, I still owe you a thanks 😁👍
