Structural Columns not cutting in plan
3 ANTWORTEN 3
Nachricht 1 von 4
1619 Aufrufe, 3 Antworten
Hi there,
I have created a canopy type structure on a rooftop of a building I am working on.
The main structural supports I have created as a structural column which is a combination of a column and beam (as can be seen in the 3D.
I am trying to create a plan where the beam part of the member is cut away and you can only see the column as is showing in the on Grid Line 1-L the reason this member is cutting is that it is a generic model. The member to the left which I also need to cut is not cutting as it is a structural column. Is there any way to get the structural column to cut in the plan without changing it to a generic model? I have unticked the 'Show family pre-cut in plan views' and it did not work.
Thanks!
Beschriftungen (3)
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
Post the file.
Nachricht 3 von 4
Do they show if the view is set to medium or fine?
Nachricht 4 von 4
JM_K
I think response #4 is applicable to your problem: https://forums.autodesk.com/t5/revit-architecture-forum/structural-framing-not-cutting-in-plan/td-p/...
Insert witty comment here.
