Structural columns in linked file - what's this time? (Revit 2017)
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
1861 Aufrufe, 10 Antworten
Sorry, I know this is a redundant post,
It's the first time I don't figure out why a column is not showing properly in a plan view.
This is a model with a structural model linked into. I checked the family column is showing right in the structural model.
As you can see, from the linked model the two columns on the left are working fine, but the other column is showing "wireframe". They're identical, same type, same offset, same properties, same workset. The walls are placed with the same offset, there's no particular view template setting set in this view, but it happens even if I create a new view from scratch.
I read that one way to solve it is to make the wall "transparent", but it's a sloppy solution and in some views there are some windows/doors below they'll eventually show up, so I need to fix it from the actual settings.
Any tips I didn't recall?? As I said, I had similar issues in past with this, I read all previous posts, this is the first time I encountered something like this.
Thanks!
10 ANTWORTEN 10
Nachricht 2 von 11
Sahay_R
als Antwort auf: Anonymous
Hi @Anonymous - try this -
Open the Structural Model
Select one of the columns (you did say that they are the same family, right?) and make sure that t his box is checked -
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 11
als Antwort auf: Sahay_R
Checked, they were set "pre-cut" by default.... This is the weird thing... On some work, on others don't ...
Nachricht 4 von 11
Viveka_CD
Hi @Anonymous
Can you share a file and recent journal to test further?
Nachricht 5 von 11
als Antwort auf: Viveka_CD
I Think I sorted it out.. Could it be involved with the "Join" status of the columns and the floor in the structural file? I think the ones being hidden are "joined" to the slab .....
Nachricht 6 von 11
Maybe. Joined elements do share the same line weight and fill pattern.  Have you tried switching join order?
...another thought: you could set up the Host View to display link "By Linked View".
Nachricht 7 von 11
als Antwort auf: barthbradley
I usually  would do that, but the structural model from the consultants is "viewless", so I prefer to apply some graphic properties this time. As soon as I spot the "weirdness" what's related to, I can handle it. Thanks!
Nachricht 8 von 11
Viveka_CD
Hi @Anonymous
Glad to hear that you've sorted this out yourself.Smiley (fröhlich)
A few related AKN articles below:
  • Use the Join Geometry tool to create clean joins between 2 or more host elements that share a common face, such as walls and floors.
  • About Concrete Geometry Joins: Concrete elements automatically join each other and are represented in the project as a single mass in all views. While joined, you can edit and move the individual elements within their normal ranges and limits.
Nachricht 9 von 11
Did you try switching join order?  Or simply unjoin?
FWIW:  http://revitoped.blogspot.com/2013/05/dominate-elements-in-concrete-joins.html
Nachricht 10 von 11
Either I unjoin some elements or changed the join order, I solved it already.. Yes
Nachricht 11 von 11
Understood, @Anonymous. Just responding to your question in this post.  At the time, there was no solution.
