structural columns automatically cutting walls and floors
7 ANTWORTEN 7
Nachricht 1 von 8
Arch.MaDo
3471 Aufrufe, 7 Antworten
Is there away to make the structurals columns automatically cuts the walls and the floors without having to choose every column and click to join it with every wall and every floor?
7 ANTWORTEN 7
Nachricht 2 von 8
semko_dm
als Antwort auf: Arch.MaDo
Hi!
Take a look at Dynamo, or another programming methods. For example, in dynamo forum this issue is pretty common and you can find couple of ways that can solve it.
You can start with 'Hot Gear' Package. It has got some nodes that fulfill what you're looking for.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
Dmitriy Semko
BIM-Manager
Blog
Facebook | Telegram | LinkedIn
Nachricht 3 von 8
wroebuck
als Antwort auf: semko_dm
This is exactly what I needed! Thanks.
Nachricht 4 von 8
semko_dm
als Antwort auf: wroebuck
You are welcome! :grinsendes_Gesicht_mit_großen_Augen:
Dmitriy Semko
BIM-Manager
Blog
Nachricht 5 von 8
crista.popescu
Hi! I'm struggling to get categories from a linked structural model. Do you happen to know a node that can interrogate a link?
Thanks!
Nachricht 6 von 8
arquitetura_03
als Antwort auf: crista.popescu
Still waiting for this answer.
Nachricht 7 von 8
als Antwort auf: arquitetura_03
Copy monitor the link structural columns to your project and run the dynamo script on those.
Nachricht 8 von 8
Martijn.Pater
FWIW Simply clicking 'Join multiple' when using the join tool might safe some time aswell, if you're not looking to use the above mentioned Dynamo solution or if you don't have as many columns (and ofcourse only if doing this manually is considered an option)...
