How do we make a concrete structural beam longer? When I try using standard architectural modification tools, like using align to alight to another element, it moves, and also I do not see a profile modification tool for a beam like the ones existing for the walls, etc.,, so I wonder then how to make it longer.
Thanks in advance.
Isn't it (the section dimensions) are controlled by the depth and the width parameter? On plan, you can stretch it to make it longer.
Structural beams should have the same blue dot as walls. Which view are you looking? Can you take a screenshot?
