Structural Analysis-default.rte Missing
2 ANTWORTEN 2
Nachricht 1 von 3
2831 Aufrufe, 2 Antworten
I downloaded revit 2017, and noticed the Structural Analysis-default.rte US imperial (English) is missing. Can someone provide this template for me or tell me where I can retrieve the template, as I have already updated my content settings and still no success.
2 ANTWORTEN 2
Nachricht 2 von 3
Lakshman01
als Antwort auf: Anonymous
Hi tbrown43,
These are the relevant technical bugs during the installation process, Make it sure to follow these steps to handle your issue.
  1. Try to repair the product or  click Add / Remove features this option could help you to fix the problem
  2. If you have another PC installed with proper Revit 2017 means you can copy the Structural Analysis Template and Paste it on your PC at the proper location
  3. Check the Revit.ini notepad file (for the purpose of Path determination)
Try these steps,  soon update to me !!
Regards
lakshman
Nachricht 3 von 3
Alfredo_Medina
Surprisingly, we cannot attach a file with extension .rte in this forum. I tried, but the system says that "the file does not have a valid extension for an attachment..."
