Stringer above needed level
2 ANTWORTEN 2
Nachricht 1 von 3
frajosorio
242 Aufrufe, 2 Antworten
I cant get the stringer to be leveled with the channels level highlighted in red in the capture. I already tried using the different trim options when editing stairs.
Thank you.
2 ANTWORTEN 2
Nachricht 2 von 3
chriskD6WP2
als Antwort auf: frajosorio
Look at the attached screen shots. You are looking for something called, "Structural Depth on Landing." That allows you to adjust the height of the stringer so it's flush with the top of the walking surface.
Nachricht 3 von 3
chriskD6WP2
Ignore that last post. Your stairs are modeled differently than what I have in my screen captures and video.
Take a look at the attached video. This applies to the way you have modeled your stairs.
In order to select just the stringer, I clicked on the stairs, then I hit the Tab key so that it just selects one of the stringers. When I did this, I got the menu showing you how to adjust the top of the stringer. You are looking for something called, "Trim Support at Upper" in the stringer properties menu.
https://knowledge.autodesk.com/community/screencast/d17e6f42-6cca-46fb-87c1-52c42bc341b8
