Strike thru text
1 ANTWORT 1
Nachricht 1 von 2
yes_and_no
496 Aufrufe, 1 Antwort
Strike thru text
Guys, someone here has a tip for striking text in pre Rv18, as shown.
I can't find the post.
Can you help ? Currently we draw lines for that.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: yes_and_no
Copyclip the text block, edit and replace the strike content with -------------------, set the test style to transparent if it is not already, then paste aligned in place over the original text block.
Also, nothing wrong with using (array) lines.
