I am getting this result from my stairs after sketching it out. What is the reason?
Gelöst! Gehe zur Lösung
Gelöst von FGPerraudin. Gehe zur Lösung
Gelöst von semko_dm. Gehe zur Lösung
Hi!
Fortunately, It's very common bug of old revit stairs.
Assembled stairs(Stairs by component) or in-place mass better used to cases like this.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
Hi Miguel,
Solution is simple: you need to addd structural depth to your stairs! (in the properties of the RUN, within te stairs)
As you can see, it is the curvature of the bottom of the below face of your stairs that cuts the threads!
Cheers,
François
Francois-Gabriel Perraudin
BIM management and coaching
Hi Francois,
I actually figured it out yesterday! and as you said it was about the depth, do not know why the software runs like this thou.
Thanks for the reply
