Good morning, I'm having trouble getting this street gutter family to line up. I have corners that are not straight and I would like it to line up with them.
Here is the situation:
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
have you tried an Model In-Place (you can categorized it as a Plumbing Fixture) and use the Sweep tool? you can create a profile to load and use for the shape of the gutter.
Howard Munsell
Model in Place is done in the Project Model, it is not a RFA Family.
Architecture ribbon > Component > Model In Place. you can use the sweep tool and use the Pick Line option and pick the arch to select your path.
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-68DBFA52-DF77-4B3F-84AC-F20194FADC64
Howard Munsell
I'll add an FYI...if your gutter is following a System Family Roof or Floor, the Roof Gutter and Floor Slab Edge will follow a curvature. You can extrude just about any profile you can sketch. Create a Profile using the Profile Template and indicate the Profile Usage. Then load into your Project and assign the Profile Family it to a System Family TYPE, such as Gutter shown in screenshot.
