strange symbol
3 ANTWORTEN 3
Nachricht 1 von 4
htews
627 Aufrufe, 3 Antworten
strange symbol
anyone have this issue before? "line break symbol"?  puts my sheets out of order.
wasnt there before.  luckily, it does not print.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: htews
Did you use pyrevot to aort sheets? It puts Unicode characters in front of the actual sheet number in order to do so. You can reset via the tool pyRevit provides in the same dropdown menu.
Or simply delete the sheet number and reenter it (use nackspace or delete key generously to make sure it deletes the invisible unicode characters).
Nachricht 3 von 4
htews
als Antwort auf: ToanDN
ah pyrevit, yes.
it says  shift-click to remove the unicode.  is this while i'm clicking on the 'print sheets' or while i'm clicking on 'one file'?
testing the later one now.
Nachricht 4 von 4
alan_eu
Just to add to this conversation:
PYRevit 4.8.4 is out!
https://github.com/eirannejad/pyRevit/releases
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou :leicht_lächelndes_Gesicht:
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! :leicht_lächelndes_Gesicht:
