Strange stair visibilty behavior
2 ANTWORTEN 2
Nachricht 1 von 3
ROCKS-01
210 Aufrufe, 2 Antworten
This stair run does not appear properly in the plan, althought it appears correctly in the 3d, the reads and riser are not shown in the plan while all the visibily items of the stair are checked
However, when i hoover over it with the mouse the treads and risers appears like in the last screen shot
I would add a note that i am using a riser and tread profiles bu i don't think this may cause that problem
I attached the rvt file 2022
If anybody would like to provide an advice
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: ROCKS-01
Plan View display of Stairs is symbolic in Revit. You have no nosing length to display.
...to be clear: what you are seeing highlighted blue is the model geometry. That won't display in 2D Plan View.
Nachricht 3 von 3
You know, FWIW, there is something else odd going on here, but I'm unable to drill down into your custom tread profile family. Seems to be corrupted. I crashed twice trying to open it.
