Strange roof cutoff
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
apdim
446 Aufrufe, 7 Antworten
Strange roof cutoff
Hey,
I created a roof and then added a cut-off level. The roof has different slopes on both sides. I'm getting strange form at the end. Any ideas how to fix it?
Thanks!
7 ANTWORTEN 7
Nachricht 2 von 8
ralphdenhaan
als Antwort auf: apdim
You can try to use Slope arrows and see if this works for you? But then you will see a litle difference at the base of the roof.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Nachricht 3 von 8
apdim
als Antwort auf: ralphdenhaan
@ralphdenhaan It is same
Nachricht 4 von 8
Simon_Weel
The only solution I can see is to draw the opening of the roof; without specifying a cutoff level:
Nachricht 5 von 8
apdim
@Simon_Weel Thank you, it worked!
Nachricht 6 von 8
constantin.stroescu
The problem is that you have different Slopes and thus when cut with vertical or horizontal planes the section thicknes will be different ( the perpendicular on face is equal)
  1. When using CutOff Level - Cut  with offset - the alignment is made to the bottom of the roof Face
  2. When using a Vertical Opening the alignement is made on the top of the roof
  3. You can Cut the roof with a Void Model in Place Family to obtain a horizontal cut and then build on the top of the cut
1
2.
3.
Constantin Stroescu
Nachricht 7 von 8
You can model a flat roof and edit sub elements, or a roof by mass faces.
Nachricht 8 von 8
apdim
I forgot that I have to reinforce it later, so I'm going to model it as the floor. Thanks for the replies!
