see photo, there is no bm 20, and its labelled and in the properties. is this a bug ?
I would assume in the Tag "BM" is an abbreviation for Bar Mark.
The Tag will only Report what it is told to report so within it I would suggest there is another Parameter or a Prefix adding this information. Select the Tag > Right Click > Edit Family, and review the Label properties.
Also you have a Partition Assigned so you could be tagging elements from Different Partitions so this would also need to be checked. The 4 bars have 2 different length but the BM20 is treating it as a group element hance the Varies reference for Length so are they a set/group/partition?
Select the tag > Edit family from modify ribbon > select the label then click on "Edit Label" from modify ribbon
From Edit Label window make sure to keep only the rebar number parameter and delete the remaining
Also make sure to remove any Prefix for Rebar Number
After finalize editing the label > Load the family into the project
If you face any problem you may share the family of the tag and I will fix the problem.
