strange lines
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
ammerlaanrens
192 Aufrufe, 2 Antworten
strange lines
Can anyone help me remove these weird lines? hardware acceleration doesn't work.
Thank you in advance.
Tags (1)
2 ANTWORTEN 2
Nachricht 2 von 3
L.Maas
als Antwort auf: ammerlaanrens
I think the issue is the text (very small lines?). Is this or part of it imported from other software? This points to issues where Revit has problems putting it properly on screen. This sometimes happens where the geometry is such that the software and/or graphics card can not properly handle it and result in these weird lines. Try to remove the text (I expect these cause the issue) and see what happens. You also can consider to upgrade you graphics card drivers. Maybe newer version handles it better.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 3
handjonathan
Hi @ammerlaanrens
Thanks a lot for posting your question to the forums!   Has the solution suggested by @Anonymous helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
