Strange graphics after join
1 ANTWORT 1
Nachricht 1 von 2
GA-LT
271 Aufrufe, 1 Antwort
Why after joining walls with columns some same walls changing graphics?
Corner is made of 2 identical walls but looks different:
Tags (2)
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: GA-LT
Check the column settings in the family. make sure "Cut with Voids when loaded" is checked. then you will have to replace the columns in question. otherwise it will fuse with the wall join conditions and gets a bit messy.
