strange behaviour of nested filled region in different visual styles
0 ANTWORTEN 0
Nachricht 1 von 1
hillagordon
142 Aufrufe, 0 Antworten
hello all,
I'm looking at a very strange problem and I don't even know where to start looking for a solution.
Trying to make a long story short, basically I built a tree in a planting family [1] , and nested inside it another planting family [2] (so I can scale everything). That second family contains a 2D tree symbol in floor plan and a detail item family [3] which contains a circle of a filled region with a color. In 2D only the tree symbol and the "color" circle are visible, not the 3D tree, and the "color" shows only in medium detail level because I use it for planting plans and not for other types of plans.
It all works great!
the problem starts when I change the visual styles. the regular filled regions I threw in behave as you'd expect, and the nested ones don't. see examples of them side by side in the different styles:
You can see it affects only shaded, realistic and texture styles.
so I'm really at a lost - can't do anything through material browser, because it's filled region. can't do anything with view template, because I can't override by family only by category which won't help, each family must have it's own color for the planting plan to work.
I just really don't know at what I need to be looking to fix it.
any ideas?
0 ANTWORTEN 0
