Straight roof cut
2 REPLIES 2
cadedu22
559 Views, 2 Replies
Straight roof cut
How can I make roof corner like that?
2 REPLIES 2
RDAOU
in reply to: cadedu22
@cadedu22
Several ways depending on how you created the roof ... Roof: By footprint/Extrusion or Face
Option 1: If by footprint (similar to the one you have) do the following
  1. Select roof and change Rafter Cut to "Two Cut - Plumb
  2. Change the Facia Depth to value as desired (See how I determined in the GIF below)
  3. Add a Beam (same material as the Roof) -
  4. use 3D snapping and Pick edge of the roof
  5. Change Y Justification of the Beams as necessary (Origin/Center/Left/Right) to align to roof
  6. Join Geometry (check multiple) >> Pick roof then the beams
Other Options: instead of the Beam you can use
  • Roof Facia
  • In Place Extrusion
An alternative method to the above is to create the roof by Extrusion (See GIF below)
Works also using Roof by Face but not as clean as the above
cadedu22
in reply to: RDAOU
That was quick answer, Thank you once again, In my case second method is must suitable for end roof polishing.
Forma Design Contest
