Several ways depending on how you created the roof ... Roof: By footprint/Extrusion or Face
Option 1: If by footprint (similar to the one you have) do the following
Other Options: instead of the Beam you can use
An alternative method to the above is to create the roof by Extrusion (See GIF below)
Works also using Roof by Face but not as clean as the above
