Is the storefront 'Function' Type Parameter for Interior or Exterior just a scheduling thing, or is there some other thing happening that I can't see?
Gelöst! Gehe zur Lösung
Gelöst von GHASEM_ARIYANI. Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
the built in Function is in general a type Property of walls (not just curtain walls)...as well as other system components. Most people do not even notice it and some do use it either for scheduling as u mentioned or for filtering/overrides. However, apart from the above, this type property also determines/effects how the components' are treated when the analytical surface are exported to gbXML.
If you do not do any solar/energy/shading analysis you do not need to worry about it.
You are welcome...
Hello @PhilvK
Function parameter It affects several factors:
* Wall drawing mode
* filter
*schedule
*Heating and cooling load
* and etc ...
please see attached video.
