Hello everyone,
I've been using Revit for almost 9 years, and storefront troubleshooting is an easy task for me.
However, after I've installed the 2019 version, some features started to act weirdly, such as the storefront.
I've faced some internet connection problems during download/installation time (which I doubted that it is what causing these issues, but after I did "repair", nothing happened and I still find no difference)
However, regarding the storefront, I noticed these weird unfamiliar steps:
1- there is no differences between a curtain wall exterior glazing and a storefront when I draw them. they both draw without mullions (photo 1). you have to add them yourself. (it's used to be added automatically for the storefront only).
2- Wall panels are automatically created pinned by default. Here you cannot pin, unpin or delete a panel! in fact, they're all grayed out! (photo 2)
3- Cannot add a door to the curtain wall. I guess, if the panel is un-editable, then it won't let you add the door.
4- Revit won't download the curtain-wall door family in anyway. I tried to add it through the Door option, the Component option, and Insert Family option. all they give the same error message "Revit Cannot Load this family" (photo 3)
Does anyone know what's the problem?
Thanks !
