stop revit from filling in instance parameters for new instances
6 ANTWORTEN 6
Nachricht 1 von 7
MVE1112
291 Aufrufe, 6 Antworten
Why does Revit fill in instance parameters for a new instance of a family, based on the instance somewhere in my project?
I place a new instance of a family, through my project browser:
But the host id and link id , which are 0 by default in the family, get filled in based on some other instance somewhere else in ym project??
6 ANTWORTEN 6
Nachricht 2 von 7
vitorbortoncello
als Antwort auf: MVE1112
This happens because Revit sometimes retains the most recent instance's parameter values as a convenience feature, assuming that subsequent instances might need similar settings. After placing a new instance, manually reset those instance parameters to their default values (e.g., 0) before making any other modifications.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 7
MVE1112
als Antwort auf: vitorbortoncello
Well Revit assumes wrong, don't you think?
There's a family default value for a reason..
Is there no way to disable this?
Nachricht 4 von 7
RSomppi
Nope.
Nachricht 5 von 7
vitorbortoncello
It will assume last used values, i guess it is a way to disable
Nachricht 6 von 7
TripleM-Dev.net
Hi @MVE1112,
This was answered a few weeks ago
When starting to place a family, the instance fields are visible on the properties palette.
When those are filled in before the family is actually placed, those values are re-used for every instance you place of that type.
So to reset it, start placing the family and set those fiels to a empty value and hit enter. No need to actually place the family after that.
Now those fields should remain the set "empty value", filling the values in AFTER the family is placed will not have affect on later placed families. (that only reserved for some builtin parameters like "Mark")
- Michel
Nachricht 7 von 7
vitorbortoncello
you can use the "Create Similar" tool
