STOP MOVING LINES IN OTHER GROUPS
1 ANTWORT 1
Nachricht 1 von 2
HAOYU33CKL
112 Aufrufe, 1 Antwort
Dear Development Team,
I hope you're doing well.
I noticed that detail lines across different groups are being affected by each other, which is causing significant frustration. The primary reason I placed these elements in separate groups was to avoid any interference between them.
Could you please look into this and implement a fix? It has been quite challenging to work with this issue.
Thank you in advance for your attention to this matter.
Best regards
1 ANTWORT 1
Nachricht 2 von 2
RC_RVT
als Antwort auf: HAOYU33CKL
In what way are they being affected?
If this works, please mark it as an accepted solution. This helps make the forum a better place.
