Stop layer of wall mid-wall
4 ANTWORTEN 4
Nachricht 1 von 5
899 Aufrufe, 4 Antworten
Is there a way to stop the outer layer of a wall when it touches with the ceiling?
As pictured, interior layer of wall is a finish 2[5], so is the bottom layer of the dropped ceiling; meaning they join, but the layer of the wall still continues.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Nachricht 3 von 5
als Antwort auf: ToanDN
Thank you, I did read that, but I only managed to change the whole wall at once.
Is there a way to do the following with the Finish 2[5] layer: Captura.JPG
Nachricht 4 von 5
Split the wall into 2, drag the layer of one wall only.
Nachricht 5 von 5
So basically what you are saying is that the wall above the ceiling is not finished on the inside.  So then, you can use a different wall above the ceiling -- or edit the Wall Assembly and unlock the existing Wall's Finish Layer at the top. This way you can drag the Finish Layer downward to meet the Ceiling in Section View.   Or, just enter absolute distance in the Wall's Top Extension Distance Parameter.
