Still waiting....it can take time. Only a couple of extensions have been released so far...
If required, you can export to DWG and from AutoCAD export as an STL file.
The stl exporter for Revit 2020 does exist.
Go to https://manage.autodesk.com/home/ and look up to
"all products & services" --> Revit --> Revit 2020 --> show all downloads --> updates & add-ons ...
there you schoud find it.
I hope my guide to the download helps a little bit, sorry but i don't know any direct link.
This is not working out for me. Has there been an update to how to get the STL exporter add on since this discussion?
I still can't find it. It doesn't appear under my Autodesk account. Could it be because we are educational?
Nevermind. Someone from Autodesk Support finally provided me with a link to download it from OneDrive because it does not appear in my download portal. Probably because we are educational?
Hi, can someone please point me towards the 2020 download? I can only see the 2018 version in my available add-ins.
Many thanks
Andrew
I can´t find the add-in in my autodesk account manage page. I only have the 2018 version but not the 2020. How can I fix it?
Thank you!
Can anyone point me in the right direction?
I've downloaded and installed all updates from Autodesk but still no STL Exporter.
Or can someone send me file for the add-on to install.
Much appreciated,
Cheers
