I have downloaded the stl exporter from here https://manage.autodesk.com/home .
After downloading and installing it doesn't seem to appear in the Revit program.
I am using a student version of 2020 if that makes any difference.
I have had both success and failure with this feat in the past, but mostly failure with a short stint of having a successful stl button.
Is there a trick to this?
I have successfully installed the Rhino Inside Revit add-on and it works fine.
Any ideas why the STL Printing add-on would not work? Or any ideas on how to fix the issue?
I may try installing an earlier version of Revit
Any ideas are appreciated.
