hello fiends, How can i find fireproofing steel column or framing in revit, so that if i highlight the column or beam i can see the check box for fireproofing on properties tab, or anyone who has such families can help me with or tell me how to download it from any site, especially wide flange beams and wide flange columns, thanks in advance
What exactly does the checkbox differentiate? Do you have some framing that is fireproofed and some that is not? Every structural steel element should be fireproofed anyway, using coating, gypsum or whatever....
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Are you looking to model the fireproofing into the steel families?
@Ilic.Andrej It depends on jurisdiction and the use of the steel members (primary vs secondary etc). Here not all steels need to be fireproofed.
