Steel Connection critical bug
We're working on a large project which contains many links. The project laggs and revit keeps generating graphics for views. With trial and error, I concluded that the Steel Connection addin caused this issue.
I would appreciate it if you look into this.
We are now unable to use Dynamo because it apparently cannot run without the steel connection addin.
