Steel beam not showing
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
mauarduz
1431 Aufrufe, 5 Antworten
Good day everyone, I am trying to make steel beams by picking the lines from a mass, once picked, Revit says the beam is there and it is represented by a (red) line, but the beam is not shown. I've looked at visibility settings it all seems in place, I cannot figure it out. Please see attached image where the inclined lines of the mass have been picked to show a standard steel beam family loaded from the library. Thanks.beammmm.png
5 ANTWORTEN 5
Nachricht 2 von 6
RDAOU
als Antwort auf: mauarduz
Change view to Medium or Fine
Nachricht 3 von 6
mauarduz
Beams now show in elevation views and in 3D, but not in plan
Nachricht 4 von 6
Have you change the plan view to Medium or Fine as suggested?  Do you want to see the beams cut by the view range cut plane or full projection?
Nachricht 5 von 6
RDAOU
@mauarduz
Your plan view is set to coarse and wireframe
  1. Set it to hidden and fine
  2. If you want to show the beam pre-cut .   You need to edit the family and check/enable the option
Nachricht 6 von 6
mauarduz
OK, solved by editing the detail level within the family, enabling the coarse view check box, in family edit mode.
