Starting with Revit
Starting with Revit
Starting with Revit
Hi I'm new to this and trying to set up Template sheets in A1/A2 size with a my own tilteblock for each. I have created an A1 tilte page but other than recreate A2 sheet cant seem to find quick method -Can anybody help.
Alfredo_Medina
Welcome to the forum. Your question is not clear enough. Please elaborate some more.
Hi basically what im trying to say is my background is architecture and ok with autocad working in model and worksheet mode creating 2 dimensional dwg files - now looking to venture out into Revit and need good starting point to speed up the process Regards Mark
Sent from my Samsung Galaxy smartphone.
Alfredo_Medina
Well, your second message did not really explain the first message better. However, let me try: you need 2 titleblock families, one for each size. Then, load the 2 titleblocks into your Revit project. Now, the two types of titleblocks will be available when you need to create a new sheet.
doni49
I've read through his first message a few times and my guess is that he is trying to find a way to make the A2 titleblock LOOK like the A1 titleblock but allow for a different size sheet -- but he doesn't want to RECREATE it from scratch.
If that's the case, create your A1 titleblock family save it.  Then do a SAVEAS and give it the A1 name.  Now modify the A2 family to suit your needs.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
