Having trouble extending stair supports. I would like the stairs supports to extend and look like what is highlighted in green in my picture. I have tried everything. This extension was very easy in Revit 2017. Did Revit 2019 loose this feature?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Is that the Top Rail? I don't remember precisely when that was introduced. Maybe that's the difference.
@Anonymous : I think I may have misunderstood. When you say "Supports", are you referring to Handrail Supports?
Ah! I see what you are talking about. The stringer properties! Sorry, I didn't see the "green" initially in your screenshot.
...and Stair by Sketch went away in 2018. There's the big difference. But, can you get that Stringer cut-off with Stair by Sketch? Kind of a two-plumb cut.
DUH. I'm brain-dead today
Thanks.
What about in 2019? I can't get there (the OP's stringer design that is). What am I missing?
