Stairs Slab Connection after Stair by Sketch
1 ANTWORT 1
Nachricht 1 von 2
sameerkhankhattak
339 Aufrufe, 1 Antwort
Hi
I have created stairs by sketch(i.e Boundary, Risers and then Stair Path). I have the classical Revit slab-stair connection problem. I Know how to solve it if I have made stairs with the runs and landing combination and that is to add a landing at the end of last run. Now since I have made stairs with Sketch, that solution is not working for me. When I draw a rectangular landing, revit gives error " stairs can't be created". Someone please answer a solution or refer to the one. Thanks
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: sameerkhankhattak
I am throwing in a couple approaches, not knowing how your stair actually looks like:
- Create actual runs  and landing, then convert runs (and landing, if needed) to sketch and edit the sketch
- Create the landing as part of the stair by sketch, think of it as it a longer step
