Stairs second floor representation
juancano_arq
Message 1 of 8
juancano_arq
Hello everybody, hope you so good.
I'm making an 2 floors project and my stairs at first floor, representatively, are very good but at second floor it looks bad, shows me "up" text, the fixed up direction is in the wrong way, doesn't cut.
Any suggestions to solution that?
Thanks!
Replies (7)
Message 2 of 8
_Vijay
tab and select the Stair path and  select which one you need as below,
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 3 of 8
juancano_arq
Hi @_Vijay, thanks for answer.
Yes, path direction it's ok but still doesn't showing cut mark, cutted lines (as first level) and full path line direction.
Do you know how to do it?
I'll let my visibility graphics and view range down for you to see it.
Message 4 of 8
Stair going from 1st to 2nd level always shows complete when viewing from the 2nd level.
Message 5 of 8
_Vijay
Try to play with plan region..may be it will give you what you need.
Vijayakumar
Head of BIM
Message 6 of 8
Best tool ever for working with Stairs in Revit: PLAN REGION.  Use them. You'll like 'em. Promise.
Message 7 of 8
martijn_pater
I suppose you could go and use plan region to 'fix' your stair representation, but I have to agree with @ToanDN though...
Btw is it me or do those stairs seem a bit steep? Or are you building a hobbit hole?
Message 8 of 8
