Stairs Riser not lining up with Stinger
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
492 Aufrufe, 11 Antworten
My riser and stingers are not lining up and it's driving me slightly mad.
I'm hoping someone can help me elucidate this. I've attached the file with the single stair.
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: Anonymous
deselect end with riser.
Nachricht 3 von 12
als Antwort auf: barthbradley
Thanks @barthbradley, it seems to work for new stairs runs.
Do you know if it is possible to deslect it for existing stairs? I can't seem to find the option and the documentation not helpful on this topic.
Nachricht 4 von 12
Nevermind, I got it. I had to TAB select the stair part of the stair instead of the assembly.
Thanks! Smiley (fröhlich)
Nachricht 5 von 12
Yes you can set it as default. When you start a new stair, open the drop-down box under "Stairs" in Properties and select "New Stairs: Run" and then deselect "End with Riser." That will remain the default until you redefine "New Stairs:Run".
Nachricht 6 von 12
Solving problem 1 created another problem...
Without the final riser, all the stairs say they are mising a riser.
I've also noticed that adding the riser, extends the thread by 1-1/4" for some reason.
Do you know if there is a way to get the final riser without the weird 1-1/4" extension?
Thanks!
Nachricht 7 von 12
That is the Nosing distance.
Nachricht 8 von 12
als Antwort auf: ToanDN
I was able to remove the nosing distance and the end of the stair looks great, but now the noses are all screwed up.
Is there a way to get a good stairs for both nosing and end riser?
Nachricht 9 von 12
Don't you stairs have a top landing?
Nachricht 10 von 12
Yes
Nachricht 11 von 12
Add the top landing see if it helps.
Nachricht 12 von 12
Highlight the Carriages and select a different Upper End Cut
