Stairs_Railing
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
Mohamed.Hesham.afifi
312 Aufrufe, 4 Antworten
Stairs_Railing
Hello everyone ,
Can i extend the baluster with the extension of the top rail ? and how ? [ i attached a photo ]
Thanks in advance
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Mohamed.Hesham.afifi
Make the railing longer and the extension shorter.
Nachricht 3 von 5
Nachricht 4 von 5
I'm surprised that did it for you. I would have thought neither making the railing longer, nor the extension shorter would work. I looked to me like that solution would be a different sized panel based on division math.  For instance, say I wanted precisely 8 panels along the total length of railing (including landing rail), I would create a panel that was sized appropriately so that 8 of them would fit nicely between the start and end.
FWIW:
https://www.autodesk.com/autodesk-university/class/Designing-Custom-Railing-Panels-Revit-2017#handou...
Nachricht 5 von 5
Thank you for your reply ,
I accepted it as solution , as i modified the extension to be near as possible from the top riser so it's goes be more realistic and i don't anymore need another panel at the floor  , however indeed i didn't get the solution for my question but i think you maybe be right with your suggestion so you give me a good point with this , if you tried this in revit could you attach it here ,
Thank you again and for this attached tutorial :leicht_lächelndes_Gesicht:
