Stairs Number of desire risers vs actual risers in the model
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
3843 Aufrufe, 6 Antworten
My head is about ot explode so decided to post a question here.
How can I make sure the desired number of risers (i.e GFFL to 1st FFL is 2,93m=17x0.1724) is exactly as the same as the actual number of risers in the model (showing only 14)?
I am sure for those with a lot of experience this might not be such a pain... So it would be lovely if I could get some assistance from you lovely colleagues.
Kind regards
Carlos Martinez
6 ANTWORTEN 6
Nachricht 2 von 7
Sahay_R
als Antwort auf: Anonymous
Create your Stair
When you go into Edit Stair, you will see number of risers as 14+4
While in Edit Stair select the stair and Drag The Run End. That will take the extra risers off and make actual risers match with desired risers.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 7
ennujozlagam
hello, see my screencast for stairs risers. thanks
Nachricht 4 von 7
luisana3BRSU
als Antwort auf: Sahay_R
Hi, I tried your solution but then it changes the height of the stairs, making the base float instead of starting on the base floor.
Nachricht 5 von 7
bimmgr952
als Antwort auf: ennujozlagam
You did not solve the problem.
Nachricht 6 von 7
bimmgr952
als Antwort auf: luisana3BRSU
Same problem as mine!
Nachricht 7 von 7
ennujozlagam
als Antwort auf: bimmgr952
rather than making a comment which we do not know what is your issue, post a screenshot of your problem so we can take a look.
