Stairs not working the way I would like
5 ANTWORTEN 5
Nachricht 1 von 6
419 Aufrufe, 5 Antworten
The architect I am working for would like these stairs to show up correctly in the model and I cannot get them to work properly.  We do not want a tread at the top, since stairs aren't actually built this way, the top "tread" would be the floor.  so I want the stairs to end with a riser.  But when I select the run and tell it to end in a riser, instead of getting rid of the tread and ending in a riser, it just adds a riser on top of my stair.  Obviously this is incorrect.  How do I get this to work like it actually should? (see attached image)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Do you have any Top offset?  Can you share the stair?
Nachricht 3 von 6
als Antwort auf: ToanDN
The way that I have made that work in the past is to put in 1 less riser then check the button and it adds the missing riser.
Maybe someone can tell us hoe to set it up to do that automatically.  I have seen posts about it but I have not been able to follow them.
Matthew
Nachricht 4 von 6
In the example above I didn't need to do what you said.  Revit did all the jobs automatically.
Nachricht 5 von 6
I do not have a top offset on the stairs.
As a workaround I removed the top riser, but I would like to know how to set this up correctly without having to manually remove one.
Nachricht 6 von 6
Can you share the stairs so I can see what is going on?
